Tele2 Interactive TV with Fritz Wireless Repeater
leventatan
Since my network hub is far from my living room, to avoid 15m long cable..I started to use a wireless repeater which works perfectly with my devices except the decoder. I connect decoder to wireless repeater with a lan cable, of course
Is there a way to make it work with a wireless repeater?
Appreciate the help.
PS: Decoder works just fine when I connect the decoder with cable to the main modem.
Beste antwoord door leventatan
Update:
After I realized that Fritz! won't be working for the purpose. I went ahead and purchased this one from mediamarkt.
"TP-LINK TL-WPA8630P KIT AC1200 Gigabit Powerline"
Tele2 works perfectly, even with a switch in between.
For new comers, "powerline" is the keyword. Cheers!
leventatan
  • May 31, 2019
Update:
Hé leventatan, welcome to our forum!
Good to hear that you've found an alternative that works, thanks for sharing!
Regards, Kevin
