Hello,
I received a package from Tele2 to connect my internet. However I can't figure out where my telephone connection in the house is and how to connect the Tele2 modem to it. Please see the img attached for the cables connections which I found in my house. The house is from year 1975.
I would really appreciate your help as I need internet as soon as possible.
Difficult telephone cable connection
Hi Igor,
I'll try to explain step by step what needs to be done to connect the modem.
1. Remove all wires except the blue and red on the bottomleft from the main connection point shown in your first picture
2. strip the cable in your last picture by cutting 1 of the plugs at the end exposing the wires, also strip away about a centimeter of the plastic to expose the copper from the wires
3. After stripping the cable you'll most likely see 4 different color wires, to know which ones to use (you only need to use 2) look at the other end of the cable you just cut and look through the plug and see which two colors are in the middle.
4. Connect the copper of two wires with the color you just saw on the topleft of the main connection point behind the screws.
5. Connect the other end of the cable directly into the DSL port on the modem and power up the modem.
If done correctly you should see the L1 light blinking before it turns on after that the Internet light should go green, this might take 10-15 minutes minutes. If it doesnt work then instead of the blue and red wires you could also try the orange and white ones, just remove the red and blue and replace it with the orange and white and see if theres any change.
Please let us know if it works!
Bekijk origineel berichtI'll try to explain step by step what needs to be done to connect the modem.
