No connection abroad
Hi
I am currently in France. I have no mobile connection nor data. Can you check?
Search manually for networks and select one.
Or did you buy a new subscription with Tele2? In that case, roaming is barred until the first two invoices are paid.
  • April 9, 2022
  • April 9, 2022
I tried manually select but failed
Johrick van Tele2
Forum|alt.badge.img+6
Hi @paulwongkwan,
Welcome to the Tele2 Community! Is this bug still playing? As Eric points out, roaming is disabled for the first two months if you are a new customer with us. Have you also tried rebooting your device? This can also help! Hope you have a nice time in France. Will you keep us posted on your findings?
