Wi Fi low signal
Hi! My apartment has 2 rooms. The router is in the living room and in the bedroom there is a smart tv. I can't connect it to internet why the rv see the signal too low (only one line). What I can do? The apartment is only 45mq! Thanks
Appartments can be jammed with other wifi signals around you.
Although in Dutch, here are some things you can do: https://www.tele2.nl/klantenservice/thuis/internet/wifi/wifi-snelheid-verbeteren/
