Wi Fi low signal
  • apr 8, 2019 6:30 a.m. UTC
  • 265 x bekeken
Daniela
Hi! My apartment has 2 rooms. The router is in the living room and in the bedroom there is a smart tv. I can't connect it to internet why the rv see the signal too low (only one line). What I can do? The apartment is only 45mq! Thanks
Appartments can be jammed with other wifi signals around you.
Although in Dutch, here are some things you can do: https://www.tele2.nl/klantenservice/thuis/internet/wifi/wifi-snelheid-verbeteren/
meesjansen
  • Blijvertje
  • apr 8, 2019 7:12 a.m. UTC
Do your other devices have internet in the bedroom?
Daniela
  • apr 8, 2019 8:52 a.m. UTC
No, just my mobile...
  • apr 8, 2019 10:06 a.m. UTC
meesjansen
  • Blijvertje
  • apr 8, 2019 3:45 p.m. UTC
What Eric says, so I would recommend you to put a wifi extender in your bedroom that is connected to your router with ethernet.
Anton van Tele2
Forum|alt.badge.img+5
I am curious if everything is solved. Would like to hear.
Greetings Anton
Anton van Tele2
Since we have not heard anything anymore, I have decided to close this topic. If it is not yet resolved then a new topic can be opened.
Greetings Anton
