Switch On Samsung Tv with Tele2 Remote
  • January 30, 2020
  • 196 x bekeken
Dear all,
Sorry I am still learning Nederlands, so not very good with it.
I just received my Tele2 TV receiver. I have configured the set and the same works very well.
I want to know if its possible to switch on/off my Samsung Tv with the Tele2 remote.
Many Thanks for your kind response in advance.
Best Regards
Anirban
Hi Anirban,
There is an option to use our remote to switch on/off you television as well. To be able to do so you will have to link our remote to your TV. With this link you can find instructions on how to link the remote, the instructions are in Dutch. Maybe google translate can help you with the instructions. If you are still struggling to link the remote please let me know which step is unclear.
Kind regards, Michiel
Michiel van Tele2
Hi Anirban,
  • February 5, 2020
Hi Anirban,
Dear Michiel,
Thanks a lot for your help! That worked like magic.. :D
Many Thanks again for your help!
Best Regards
Anirban
