Connecting TV Receiver with wireless router with wire not working
  • February 5, 2020
  • 244 x bekeken
Hello all,
I recently subscribed to TV from Tele2. I connected the TV receiver with the Tele2 modem with wire and the TV works fine. However, I wanted to move my TV to a different room, so I configured a wireless router in the room. The wireless router works fine, if i connect my mobile(wireless) or laptop(with wire) however if i connect the tv receiver to the router it doesn’t work. I only see the message ‘Bezig met opstarten’ but nothing happens.
It would be great if anyone can please help!
Many Thanks in advance.
Regards
Anirban
That will not give you a TV connection. That must always be direct between the modem and the decoder. Like here.
  • 7115 reacties
  • February 5, 2020
That is not possible. You can try with powerplugs.
  • February 5, 2020
Thanks for your response Eric. Did you mean any powerplug from the market or something specific to tele2? The link in the email takes me to Ikea.. :P
Thanks again!
Regards
Anirban
  • 7115 reacties
  • February 6, 2020
Yes, can be any brand.
  • February 8, 2020
Thanks Eric, I shall try to get one. By the way I am using Netgear WN3000RP as of now.
Regards
Anirban
  • 7115 reacties
  • February 8, 2020
  • Oud moderator
  • 716 reacties
  • March 26, 2020
Topic closed due to inactivity.
