Junction box
Hello , so i was missing a junction box , saw a solution on other post here , so i called customer service and they ordered and i will receive it in max 3 working days , so what i am asking for is how to install that , is that some kind of adapter or modem ? or its going in the wall ? cause this is all i already have , not sure if its the right thing...
Beste antwoord door Anonymous
Thats the wrong thing, thats for cable and useless to connect to when you use a phone line (adsl/vdsl)
You need to locate your ISRA point, its in the closet where the electricity gas and water meters are placed or in your living room.
Look for a connection like the pic from the link, probably like the second pic from the right.
https://www.google.com/search?q=type+isra+punten&oq=isra+punten&aqs=chrome.3.69i57j0l3.8205j0j4&client=ms-android-samsung-gs-rev1&sourceid=chrome-mobile&ie=UTF-8#imgrc=zEfrnH7gsanpkM:
And you need to connect a Modem to it, the package Tele2 is sending you contains that.
