Hoi! Sorry, I need help in english!
So I got my modem for home internet and I got sms that I can install it.
I have the type 2 plug, so when I switch on the modem, the power button remains orange and after 1 minute it twinkles red and then it just remains red all the time! DSL lights doesn’t show nothing. (Tv light twinkles green)
What could be the problem and how should I fix that?
Thanks for any help!
Help with modem
Beste antwoord door Anonymous
Why its there? (socket on your picture) Phone connection before the time that DSL existed, that is an aducated guess from my part
Ok so when you have the ISRA point on the first floor then there is where the Tele2 Modem should be connected to because the kabel that sits in between the Tele2 Modem and the ISRA point has a restriction of 2 meters.
It is the max that the cable is allowed to be for a good connection (to long isnt good)
Then you have to bridge the 2 floors to recieve a signal, you can use a UTP cable for that or use powerplugs.
But you say you live on the thirt floor then i assume that you live an an apartment with renters beneeth you.
That you are not the uhm lets say the houselord. when that is the case your houselord will know what your sittuation is exactly.
If you can use the socket on your floor etc.
