  • September 7, 2022
  • March 13, 2023 at 1:33 PM
  • 108 reacties
  • 92132 x bekeken
iPhone 14
iPhone 14 Plus
iPhone 14 Pro
iPhone 14 Pro Max
► Verlenging: Ga snel naar MijnTele2 (via laptop of computer), zodat je direct kunt verlengen! 
Bestelling en levering
Bezorging via PostNL:
108 reacties
  • September 12, 2022
I have existing subscription for calls/data from Tele2, which is until 2024. But I want to upgrade my phone and buy iPhone 14 pro, which comes automatically with calls/data bundle. Obviously I don’t need 2 subscriptions for calls/data. How can I get a new phone with calls/data bundle, while terminating my existing subscription?
WhTurner
@Alibek
Do you have a SIMonly subscription (without payment for phone), or do you have a subscription with phone?
Tele2 Sim Only, it does not have the payment for the phone, and will end only in Feb 2023, which I don’t want to wait :)
Login to the.my tele2 app and look for the button 'verlengen'. You should be able to prolonge your simonly to a new subscription with a phone.
On website there’s a page for “verlengen”: https://www.tele2.nl/mobiel/abonnement-verlengen
I click “Yes! Ik wil verlengen”. Next page suggests choosing “sim only” or “phone with calls/data bundle”, I choose the last one.
Next page is kind of dead-end:
so it says “Betaal eenvoudig online je nog openstaande rekening. De verwerking hiervan zal tot maximaal 3 werkdagen duren. Daarna kan je verlengen.”
But when I click “Naar online betalen” there’s no possibility of making that outstanding payment. Actually I think it doesn’t make sense to make outstanding payment as I’m increasing the amount of spending with tele2 by getting a new phone which comes with calls/data bundle.
Isn't there any (late) Open invoices to be paid? You can find that under 'facturen '.
  • September 13, 2022
There is no “open” invoice to be paid. Only the ones that I’ve already paid in the past:
Same here Alibek,
something is going wrong in this system. I hope will get my new iphone soon.
Er gaat iets niet goed Eric, de betalingen zijn gewoon gedaan en dat zie je ook bij openstaande betalingen dat zijn er namelijk 0. Ook de gedeeltelijke betaling van de Iphone is succesvol verricht.
Johrick van Tele2
Forum|alt.badge.img+6
Hi allemaal, de levertijden zijn zojuist bijgewerkt. Check snel of de wijzigingen ook invloed hebben op jouw toestel! Mochten er nog vragen zijn, hoor ik het natuurlijk graag.
  • September 16, 2022
Betekent dit nu dat alle orders van de iphone pro zwart van 09.09.2022 pas over 4 weken komen?? Hoe kan dit ineens?
Hi Johrick,
Ik kamp momenteel met hetzelfde 'probleem’. Ik heb overigens al contact opgenomen met de klantenservice (via chat). Hieruit kwam dat de levering momenteel vertraagd is en dat iedereen inderdaad langer moeten wachten voordat wij ons nieuwe toestel in ontvangst nemen.
Het vreemde is, is dat ik ook contact heb opgenomen met de klantenservice van Tele2Nederland (Twitter). Zij hebben mij verteld dat de nieuwe leveringstijden niet gelden voor pre-orders. En dat de personen die de pre-order hebben voltooid op 09-09-2022 vandaag een mail ontvangen wanneer hun toestel wordt geleverd.
Is wat mij betreft een kwestie van afwachten. Het lijkt mij zeer sterk dat wij nu nog een mail vanuit Post-NL ontvangen dat ons toestel vandaag zal worden geleverd.
For me it says that I cannot “verlengen” 🤷‍♂️
“Sorry, je hebt geen abonnementen die je kunt verlengen”
Johrick van Tele2
Hi @iamrule, yes, dat klopt inderdaad! Ik begrijp dat je je nieuwe iPhone zo snel mogelijk wilt hebben! We hebben nooit een belofte gedaan, het is voor ons ook altijd afwachten welke eerste voorraad we binnenkrijgen. We werken via de ´´First In, First Out´´ methode. In het topic houden wij je graag op de hoogte!
Hi @PierreB, ook voor jou geldt het bovenstaande. Ik snap dat er wat verwarring is en zal dan ook voor je gaan uitzoeken wie jou deze informatie heeft gegeven. Je zult van ons een mail krijgen met bezorging alleen wanneer het toestel ook daadwerkelijk bij ons binnen is. In de topics staat hoelang het kan duren voordat wij de toestellen uit leveren, de datums die erbij staan zijn vanaf datums. Hopelijk is het zo duidelijker voor je!
Hi ​​​@Alibek, how nice that you want to renew! The message you're getting actually says that you don't currently have a subscription you can renew. If you would like help with purchasing a subscription, you can contact my sales colleagues at: 0800-1602. If there is anything else I can help you with, please create a new topic so I can help you best!
Oké, bedankt voor het snelle antwoord.
Hoi Johrick,
Bij mijn bestelstatus staat wel dat mijn bestelling is overgedragen aan AMP en dat ik binnen drie werkdagen een bezorgafspraak kan maken. Geldt dan voor mij ook de geupdate indicatie?
Ik heb inmiddels antwoord, mijn toestel is onderweg. Toch bedankt!
Ik heb hem vandaag ontvangen :) Had ook al om 14:10 de bestelling compleet.
Vrijdag 9 september al om 14:10 besteld. Enkele dagen nog een pre-order gedaan voor een familielid. Beide iPhone Pro 256 GB zwart. Meer dan 10 keer aan de telefoon gezeten omdat het betaalsysteem niet werkte. Dagen later pas kunnen betalen. En dan vandaag te horen krijgen dat de levertijd 4-5 weken is. Ik zeg niet dat Tele2 beloftes heeft gedaan, echter hebben ze hun zaken niet op de juiste manier geregeld. Elke medewerker zegt wat anders, echt bijzonder om mee te maken.
Om dan vandaag te zeggen dat het niet te voorspellen is hoeveel er geleverd wordt is natuurlijk makkelijk. Iedereen klaagt over dat de iPhone Pro 256 GB zwart 4-5 weken levertijd heeft, ondanks een pre-order. Ook op het forum van jullie moederbedrijf!
Vandaag het toestel gewoon los zonder wachtrij besteld bij bol.com, Belsimpel, en Apple Store. Bij Belsimpel voorraad zat! Allemaal direct leverbaar! Dan heb je als Tele2 toch echt niet je zaakjes op orde of Apple heeft minder geleverd dan besteld, maar wees daar dan transparant in. Wat de reden ook is. De communicatie en informatievoorziening is echt bedroevend. Schil contrast met vorig jaar.
Benieuwd wanneer er geleverd gaat worden, hopelijk binnen de 14 dagen anders moet ik het losse toestel houden en jullie abonnement annuleren.
Alisha van Tele2
Hi allemaal,
Wanneer jij kan gaan genieten van je nieuwe iPhone is afhankelijk van de voorraad die we vanuit Apple binnenkrijgen. Ook heeft het type iPhone, de geheugencapaciteit én de kleur die je hebt besteld invloed op de levertijd. Stel dat je een heel populair model hebt besteld dan is de kans er dat je langer moet wachten omdat de vraag hoger is dan de voorraad die we hebben ontvangen. Het liefst zien we dat iedereen vandaag nog van zijn prachtige nieuwe iPhone kan gaan genieten, maar hier hebben we geen invloed op. Zodra het toestel op voorraad is ontvang je automatisch een e-mail om een bezorgafspraak te maken (AMP). Via PostNL ontvang je een e-mail met daarin de bezorgdatum. We doen er alles aan om je toestel zo snel mogelijk te leveren!
  • September 23, 2022
Zoals ik al 7 dagen geleden al schreef is het een grote puinhoop. Ikzelf heb hem om 14:15 op de pre order dag besteld. Mijn moeder 2 dagen later. Exact hetzelfde toestel, kleur, GB’s. En dan verzekerd worden van het First in, First out systeem door alle 10 de medewerkers van Tele2 die ik gebeld heb. Nou dat is de grootste grap. Want je raadt het al. Mijn moeder heeft inmiddels de afspraak al gepland. En ik heb nog helemaal niks. Toestel nog niet op voorraad staat er. Echt top gehandeld Tele2, jullie weten duidelijk niet hoe jullie eigen werkwijzen in elkaar zitten.
  • September 26, 2022
Een vriend van me heeft zijn iPhone een week na mij besteld en heeft hem nu al geleverd gekregen. Exact hetzelfde model alleen een andere provider. Waarom wordt er zo geprutst bij Tele2?
De voorraad die Tele2 ontvangt van Apple zal een andere mix zijn dan die deze andere provider ontvangt. Er blijft Apple schaarste.
  • September 29, 2022
Ik heb op 13 september besteld, iphone 14 pro max paars. Wanneer krijg ik hem binnen?
Het is nu al 3 weken geleden dat ik de Iphone 14 Pro Max Deep Purple heb besteld en nog steeds geen informatie, vind het een beetje absurd worden met hoelang het duurt. Iemand enig idee hoelang ik nog moet wachten en of hier enkele compensatie voor gegeven gaat worden n.a.v. de mededeling dat de levertijd 1-2 dagen was en niet weken.
Hi Lorenzo,
Zelfde probleem hier. Heb meerdere malen contact opgenomen met de klantenservice en helaas keer op keer verkeerde informatie ontvangen over de levering. Ik begrijp wel dat Apple hier de touwtjes in handen heeft en bepaald wanneer wij de iPhones zullen ontvangen.
Hoop dat dit zo snel mogelijk is maar heb hier zelf een hard hoofd in, zal mij niets verbazen als wij onze iPhone pas rond november zullen ontvangen. Gezien er geen ‘positieve’ updates zijn ga ik er vanuit dat Tele2 nog helemaal geen updates hebben ontvangen over hun volgende levering.
