No connection from aboard
  • 9 April 2022
  • 28 x bekeken
Hi
I am currently in France. I have no mobile connection nor data. Can you check?
Beste antwoord door eric 9 April 2022, 08:55
Search manually for networks and select one.
Or did you buy a new subscription with Tele2? In that case, roaming is barred until the first two invoices are paid.
I tried manually select but failed
Reputatie 4
Hi @paulwongkwan
Welcome to the Tele2 Community! Is this bug still playing? As Eric points out, roaming is disabled for the first two months if you are a new customer with us. Have you also tried rebooting your device? This can also help! Hope you have a nice time in France. Will you keep us posted on your findings?
