Bekijk origineel berichtLight Internet installation
Hello , so i ordered Light 12 mbps internet speed on my address , and i am not sure what will i get ? just one modem ? or they will install something else ?
After ~3 weeks you will get a modem with installation instructions. This is a do it your self package.
The installation guide, and an option to hire an installer can be found here: https://www.tele2.nl/klantenservice/thuis/installatie-door-een-monteur/
but , how do i connect modem to computer ? wireless or with ethernet cable ? does the installation requires does cables in walls ? .. sry im not really familiar with that, but if its only modem , ill manage it myself .
and what model will i get ?
You get 1 Modem that you hook up yourself, then you can use the Wifi signal that it broadcast or use a UTP cable the you connect to your Modem ore both.
Its a do it yourself package.
do you know which models they deliver usually ?
Probably not a dual band but 2.4MHz Wifi (B/G/N)
https://www.tele2.nl/thuis/internet-light/#/
