Since my network hub is far from my living room, to avoid 15m long cable..I started to use a wireless repeater which works perfectly with my devices except the decoder. I connect decoder to wireless repeater with a lan cable, of course
Is there a way to make it work with a wireless repeater?
Appreciate the help.
PS: Decoder works just fine when I connect the decoder with cable to the main modem.
Update:
After I realized that Fritz! won't be working for the purpose. I went ahead and purchased this one from mediamarkt.
"TP-LINK TL-WPA8630P KIT AC1200 Gigabit Powerline"
Tele2 works perfectly, even with a switch in between.
For new comers, "powerline" is the keyword. Cheers!
Hé leventatan, welcome to our forum!
Good to hear that you've found an alternative that works, thanks for sharing!
Regards, Kevin
