startup problem
  • 29 December 2019
  • 128 x bekeken
I ordered the internet should be up and running a few days ago.  I still have no connection.  the hotline cannot be reached, the message is displayed
Connection could not be established: Concentrator not reachable
ll00__md.gif Your DSL connection is down. Verify that your MediaAccess Gateway is correctly connected to your phone line. If the problem persists, check your documentation
Beste antwoord door Anton van Tele2 2 January 2020, 10:43
Badge +5
Hello Niesio,
How annoying that your connection is not working properly yet. Which lights do you see on the modem? Where did you connect the modem? Have you used our cables? I like to hear it.
Greetings Anton
the DSL light is flashing green.  I use your cables.  I have two entries in the meter box and in the living room.  there is no connection on any of them.  now the modem is connected in the salon.
Badge +5
Then it is possible that no signal comes in. I would like to check that for you.
Can you send me a private message with the following information:
  • Full name
  • Full address (including zip code and city)
  • Date of birth
  • Last four digits of your IBAN number.
I like to hear it.
Privébericht naar Anton
Greetings Anton
Thank you for your help.  the technician is repairing the connection
Badge +5
Good too hear! I see that the connection is currently working. The engineer has solved it well for you. Have fun with the working connection.
