I am in a network problem today as of 12 o'clock. I have tested my phone there is no problem. Can you take care of the subject? (I have been using the sim card for only 25 days)
Tele2 is integrating with the T-Mobile network. For that, sites from Tele2 are temporarily closed. But you can use the 3g and 4g network from T-Mobile already now. What networks do you see when you manually search for networks?
